Help please, following extensive testing and monitoring into why my A Class W169 battery goes flat in after three days unused in the garage, I have three questions. (I am confident that drain current is well below 50ma but battery still collapses after three days.)
1) The alternator performs well it produces 14.1 volts even with a full load of Air Con etc and i monitor it with a DVM during journeys.
I have noticed that it does not produce a charge Voltage until I put the car in gear. (Not revs related, revs dont produce the 14V just putting it into gear does) and so it could be a few seconds before it is charging, it runs fine no problems and leaves the battery at !2.6V after any journey.
2) Externally charge the flat battery (new one from MB) after 24 hours it reads 12.29V before being refitted is that an excessive drop? in the greatest scheme of things? It will start the car and there will be no problem while the car is in use.
3) As a matter of interest only I have noticed that with the battery removed there is a constant 300 mv seen across the open battery leads,
where could that be generated?
Thanks for looking
Thanks for looking
