architect1337
- Feb 16, 2012
- Mercedes W203 270CDI Classic
I'm getting some strange issues with my W203 C270 CDI
When starting the car, sometimes the lights on the front panel flash and car either doesn't start (turn key and no cranking) or starts then stalls. As it's summer, air con is on etc. I also notice that once, while driving, all the lights on the display lit, then went out. No issues with the car.
I checked the battery voltage using OBD2 (no codes showing by the way) and the battery showed 11.2V. When I started the car, it went up to 13.5V.
This all happens occasionally. The battery is factory fitted so must be about nearly 8 years old.
Would a battery on the way out exhibit these symptoms to the electronics? Why would car stall about three seconds after starting if its the battery?
Thanks for any advice. I don't want to spend money if I don't have to (and have just spend out £500 on the automatic gearbox!)
