DITTRICH
Dear All
My C230k's battery has run down as it has been parked up SORN at the parent's house. They are supposed to run the engine for 30mins every week, but what ho! - its flat, even with a solar trickle charger.
What I think I need to do is...
1 open the C230k boot manually and disconnect the negative.
2 hook up the jumper cables from my W124 E300D engine compartment to the c230k battery - do the positive lead then the negative. **Note to find where in W124 engine compartment there is positive and negative feeds**. There ought to be ample juice in this W124 **big** battery and the jumper cables are bigger **diesel** ones.
3 start the E300D engine and run the engine for 15 mins to put some charge back into the C230k battery.
4 disconnect the jumper cables. Reconnect the c230k negative cable to the battery. hopefully start the C230k from its own battery.
I have been told that the C230k has an electronic instrument cluster and to avoid any unfortunate events, I should disconnect the negative lead.
Is my cunning plan sound or is there a tiny flaw in it?
Les
Les
