JohnnyW202
- May 22, 2011
- 2004 Mercedes E270CDI Elegance Saloon, 2004 C200 Kompressor Estate Avantgarde SE Sport Pack
This is pretty much the one remaining problem with my 202 and it's a little bit annoying
It's had the new style belt tensioner and shock fitted along with a new pulley. However, at idle particularly when the car is placed into Drive or the A/C is turned on, the tensioner will rattle. The Belt is also new and the correct part for my particular car... fitting another belt let to a horrific squealing noise (Too tight)
So I'm at a bit of a loss...
Considering it's had the following done to it;
New Bilstein B4 Touring Shocks (Which I think are now as hard as B6's given the firmness in the ride now.
Brake Fluid Change
New Discs all around
New Handbrake Shoes
New Rear Window Regulator
EBC Ultimax Pads Front + Back (I know only Stock quality)
Rear Axle Carrier Bushes, both front and back.
New Front and Rear Springs (Standard, Classic/Elegance)
I've given her a lick of paint to cover up all the rust and it looks alright from a distance but she's not perfect, but at least there's no rust.
Converted her to LPG.
So yeah any help much appreciated.
Brake Fluid Change
New Handbrake Shoes
