chesterpiglet
- Oct 8, 2008
- Mercedes W211 E280 Cdi Sport Estate
When I got my W211 E280 in August the bulbs were very yellow & hardly illuminated the road at all. First the n/s bulb blew & very shortly afterwards the o/s. Just fitted the new Osram Xenarc D1S bulbs & the o/s is still not working. Presumably the only other thing is the ballast? Just bad luck that I blow 2 bulbs(which were old) & the ballast goes on one side too or is there something else going on? Swapped the bulbs over & it is not the bulbs(ie both work on the n/s but neither on the o/s). I looked for a fuse & 66 does both left & right front lamp unit so as one is working it isn't that. Both bulbs were actually shattered too- is this normal when a Xenon bulb goes? It looks to be a Hella 5DV 008 290-00- should I replace them in pairs? Many thanks.
