Bilstein Circlip
RIAXH
BERKSHIRE
E320 CDI, Carlssons,Eibachs,B8s
Hi, I have a set of Bilstein B8 dampers.
I wanted to know if lowering the Circlip adjusts the ride height???
Unless you have a 211 with the clip on the front shocks.
thanks for the fast response.
I do have a w211.
I thought they were adjusted with the Circlip.
Ok then the circlip adjusts the spring height as it sits on the spring.
so moving the clip up will result in a highier ride height,
and down will result in a lower ride height.
considering I have stiffer eibachs,
