John_Doe
- May 5, 2011
- C32
I haven't used the car for a few days and when I went to unlock it, it was dead. Thought maybe it was just a remote problem but car wouldn't start at all. And it was just my luck that i basically parked it in a hedge so was a bit tricky trying to jump start it with no access and not being able to move it. Anyway got it started and had a few error messages like ESP not available.
I know I will need to buy a new battery but obviously need to find the cause of the battery drain first. So out of the following what is my likely culprit
-Passenger door logo pogoing (been doing it for a while and aint noticed an issue with battery until now)
-Rear head rests did not drop after pressing the button and since being parked up last I found the problem. Was a cut tube feeding the passenger side rear seat. So reconnected and they now work. Can't see this causing an issue but its one of the things I've touched since the last time she was running fine. And a bit strange that it was just cut for no apparent reason.
-The only other thing I touched is the TV tuner in the boot. I literally took out all the boot lining to have a little browse. I didn't disconnect anything all i did was unbolt the TV tuner to get a look at the back for a part number. The reason I mention this is because when the battery first went flat I suspected the boot light was left on due to no lining (did this on my w202 before) but the light was off, although I did notice that the tv tuner was making a high pitch whine. I disconnected one of the plugs which only has two cables on it, red/yellow and brown, so guessing perm power and earth? Which obviously made it shut up.
Jumped the car and plugged it back in and drove it too work, parked for 8hours, started fine and came home. Over night the battery has gone flat again and now creating a very loud annoying ticking which is probs from the alarm having no power but its too late to care! disconnected the tv tuner again and the ticking gets louder lol. So plugged that back in. Not over keen on my neighbours but I don't really fancy someone knocking in the middle of the night asking me to shut it up!
I go on bloody holiday in 5days for two weeks so don't really fancy having it flat the whole time I'm away. Its gonna be parked in a locked garage and all that crap but still not the point lol
