Aletank
I replaced my Bosch MAS 9 months back from airmassmeters.com with a genuine Bosch.
My symptoms were - Jumping into gear on 1st start up from cold, drive or reverse gear.I had just that for a while before I started to get the loss of power etc and would be fine after a restart.
I fitted the new Bosch and what a transformation ! everything was sorted !
I've started recently getting the jumping into gear when cold on the 1st start up again after only 9 months/5000 miles.
I've just sent airmassmeters.com a email and here's their reply
If it is the MAS - why has it only lasted this long ?
What do you think i should do ? not long left on the warranty ! so i can't really leave it much longer to see if the loss of power symptom kicks in.
Thanks for any advice![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
I have my original MAS to use as a temporary but I'm not 100% confident it is the MAS.Bosch give a 12 months warranty, so that is within this.The part will have to go back to Bosch and they will check the part out and if faulty we will refund you.
We would need all of the vehicle details chassis no and reg etc also mileage used.
To keep the car on the road you would have to purchase another part from us if you wish or if you still have the old one that could be refitted until Bosch have checked the part out.
Please make sure that you are confident that the part is at fault before you return it.
