If you use the correct pressures (as on the fuel flap) and put the car through a professional alignment check & adjustment, your tyre wear should be more or less even. You can find a good alignment shop here:
www.AlignMyCar.co.uk
Mine do the same, now on my 3rd set in a year.
I'm experimenting with 2psi increase in pressure to try and bring the wera to the centre of the tread but I'm not expecting much to be honest.
I read on here that some of the manuals advocate moving front tyres to the back after about 5000 miles to reduce this, it is characteristic of the setup of the car and mine does it too.
On both our Audi (FWD) and Vito (RWD) the front tyres wear at the outside edge ... particularly the nearside one. Largely down to roundabouts, I think.
I swapped the Audi wheels front to back last weekend.
