A clean up as above and then a coat of Hammerite silver then makes them easier to clean in the future.I have exactly the same issue on a W213 with the Sport calipers / the same finish as yours. They are almost designed to look bad after a few years. Chipsaway guy suggested painting them.
Let us know how you get on.
A porous caliper - I somehow doubt it!I took the car back to the same car wash and got a further improvement on the improvement before. I’d definitely recommend pressure washing.
I think the issue is that the surface of the caliper is not smooth but instead is lightly pitted, maybe even porous.
Washing with a sponge doesn’t get into the pits and a conventional wash brush will never be stiff enough. For me at least, pressure washing is the answer.
Wire brush or drill, then sandpaper, then lots of brake cleaner, then calliper paint in colour of your choice (spay or brush) Won't be as good as professional refinishing but will be a lot better than standard plus a few years like yours. And you don't lose your car for a week or so. Mercedes and AMG transfers or stickers from Ebay to finishI have exactly the same issue on a W213 with the Sport calipers / the same finish as yours. They are almost designed to look bad after a few years. Chipsaway guy suggested painting them.
Shall we form an orderly queue?Fallout remover works well to get them clean. Then im a big fan of hammerite smooth. Ive found a good method is to roughly mask the caliper then brush paint the first coat to get into all the fiddly bits. Then if you're careful and generally good with a spray can you can dust a thin coat on the more visible part of the caliper to get a better finish. Ive got it down to a fine art now and looks as good as powder coat. Old towels can be wrapped over the bits you don't want any overspray on. Then you can apply the decals when touch dry.
Ha ha - well i have to finish restoring my vintage lawnmower first. Im sure there must be a hole in the ozone layer above Guildford with the amount of aerosols im getting though!Shall we form an orderly queue?![]()
Actually on that note id be tempted to try Paragon paints enamel on any other calipers i do. Ive been using their hammered paints on my mower (its a 1966 ride on contraption). Their paint is superb and the enamel i think should be good enough with the heat. The hammered effect is very subtle from an aerosol and i think it would work great.Ha ha - well i have to finish restoring my vintage lawnmower first. Im sure there must be a hole in the ozone layer above Guildford with the amount of aerosols im getting though!
Understanding What the contaminant is will speed things up.......I took the car back to the same car wash and got a further improvement on the improvement before. I’d definitely recommend pressure washing.
