brake discs under warranty
mercmanuk
MIDDLETON MANCHESTER
C180 AVANTGARDE SE SPORT GONE AND MISSED LANDROVER FREELANDER 2 LET IT SNOW LET IT SNOW LET IT SNOW
under the 3 year manufacturers warranty are brake pads and discs covered?.i can understand pads not as the old wear and tear but discs
I've only known discs be replaced through corrosion, not through wear.
hehe , you gotta be joking :) if they can even think about charging you for something during the 3 year warranty they will do it.
I think you would have a hard time trying to get a new set out of the dealers, unless they have cracked, warped, corroded.
Let us know how you get on though!
had a set swapped by a jag dealer on my s-type, rear pads and discs for a recall and front cos they reckoned they were warped, not bad at 20k miles
kenny
Anyone know where we can obtain a written copy of the MB used car warranty? I'm having a similar problem with my brake discs at the moment and MB Watford won't replace them under warranty even though they admit they are corroded.
what mileage you done mate?
I had a set swapped by the dealer on mine to cure persistent squeaking - if they are just worn out though, I don't think you will have much luck :(
S.
Shude said:
discs are consumables.
Unless they are deemed to be faulty, through corrosion or they are warped. I've had a set replaced under warranty, although that was by Lexus who would do pretty much anything to keep you happy.
