Justintyme
I am planning on changing the brake fluid in my 2010 E class w212. It has 227'000 Klms done. It's my 1st time doing this particular job, and I would like if anyone who had previously done it, could give me some pointer's? I was planning on siphoning out all the fluid in Master Cylinder, replacing it with new fluid ( DOT4 ), then going to the rear wheel furthest from the master cylinder resavoir, and vacuuming the fluid out until the new fluid appears. Then on to the other rear wheel repeat, then to the front, same process. While this is going on... do I need to have the engine running, and some one sitting inside, pumping the brake? This was the approved method in older cars, but I'm not sure if it is suitabe for the W212? I have an iCarsoft 11, will I need to use this at any stage in the process? Thanks for any help you can give.
Regards, Justin.
Regards, Justin.
