- Nov 6, 2007
- Location
- North Oxfordshire
- His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
^ This is the bit that most people miss.and just as important the corrosion inhibitors get depleted over time.
I’ll make a small wager that if you were to strip the calipers and/or master cylinder you would find evidence of corrosion. It’s certainly been the case with every motorcycle brake system I’ve stripped when the brake fluid hasn’t been changed for years.I have a 24 year old motorbike that only ever had the brake fluid changed once at last year
It’s similar to the argument that you don’t need to change spark plugs at a timed interval because very few miles have been covered since they were last changed. Then, a few years later, you find the plugs seized into the cylinder head and you’re in a whole new world of pain.
