brakes
KBJ
Gloucester
SLK
Hi
Looking at upgrading front brakes only on my 320 slk, same size just thought of going to drilled and grooved, does anyone know if this would cause any problems.
KBJ
Hi
KBJ
Hi
for looks or performance??
for performance, stick with oem or slotted if you track your car and use an aggressive pad compound, (use a good high carbon cast iron disc) something like Brembo sport range.
mazza
I have EBC Slotted disks but they do say they need to be used with a performance pad. I use EBC Red stuff pads.
Won't cause any problems at all I'm running drilled and grooved discs front and rear stainless steel flexis AP calipers and Pagid pro pads made the world of difference over oem
