Let's hope he checked your brakes etc better than that wheel eh?
Obviously being pleased that my paperwork is now good for another year, I did think about this. I do plan to take the car to a good specialist for a full service....
Yes.In preparation for an MOT bought new tires and when fitting them was informed that one wheel is buckled. The installer said it might be difficult to balance but it balanced with no issues. I asked whether it will fail MOT and he answered "No, they might not even notice it" (I suppose it is more noticeable on the picture as the tyre is still not fitted). However search on the internet suggests it might be an MOT failure.
I do not know how this buckle appeared as I have no recollection of any very bad pothole or curbing. Many cars ago I had a very, very bad incident when two tyres lost pressure instantly and even that did not damage alloys other than some cosmetic scratches. So. potentially I had this for years - since I bought the car.
For the last few months I had some annoying noise when driving which I thought some sort of air vibrations. No vibrations at all were felt through steering wheel and the noise in question was independent of the road surface be it smooth new tarmac or concrete roads on which there were wheel vibrations and additional noise from tyres.
So I will either straighten this one or will buy replacement wheels on ebay but that will take time. The question will this one pass an MOT?
I can’t see how Quik-fit could have done that amount of damage by simply removing and fitting a tyre. That damage looks like the result of a fairly heavy impact. The crack doesn’t show in your first photo so has happened post Kwik-fit, possibly the result of trying to straighten it? Your old tyre was probably ‘stuck’ to the rim and held air, after that seal was broken it couldn’t be remade.Obviously I do not believe that my wheel had all this damage before Quick Fit as it was holding air perfectly for years.
Fair enough, although your statements are a bit contradictory. I just can’t see how any blame can be attributed to Kwik-fit in this instance.Yes, not necessarily Kwik Fit is responsible for all the damage (or any of it), especially the crack... All I am saying that I can't believe my wheel had all this damage (including quite a massive crack on the front) before it went to Kwik Fit given that it was not loosing air at any noticeable (over long period of time) rate.
Kwik Fit pointed out damage (major buckle/deformation) that should have been perfectly observable prior to them removing the old tyre only after they removed it. And the new tyre was loosing pressure very badly after their work.
The wheel straightener pointed out the crack only after he removed the tire, in fact the picture he took is of the wheel on the straightening machine, but claimed it was there rather than caused by attempts to straighten.
OK it’s all Kwik-fit’s fault.If we assume Kwik Fit are not responsible for any damage for the wheel, nevertheless they took a wheel with a tyre on that was not loosing any air in and on the way out there way a wheel/tyre that was loosing air badly. The deformation of the wheel could have easily been seen prior to removing the old tyre from it - so they would have been beyond reproach if they pointed out the deformity prior to removing the tyre and explained consequences correctly prior to proceeding to remove the old tyre. (I was standing there near my car all that time)
They pointed out the deformity only once they removed the wheel, and their advice was that there might be difficulty balancing it - not that it will be loosing air haphazardly.
If the damage was such that could only be reasonably seen after removing the tyre, say some very horrible corrosion inside, then again they would have been beyond reproach if they pointed that out only after removing the old tyre. But the buckling in question could have been easily seen prior to removing the tyre so if they proceeded to remove the tyre they are deemed to have accepted it would not be an issue.
Compare that to a plight of a car renter. Much more difficult to identify every scratch and every dent on a car you are about to rent, often at night in some airport after a long flight than to spot such a major deformity on a wheel. Yet fail to identify some scratch and on return, chances are, you would be deemed to have caused it and would be charged a fortune for it (often much more than the true economic cost of that scratch). Then, if you are super-honest and super-righteous, you would have to declare it to your own car insurer who would, chances are, charge you even more for it over the next 3-5 years.
I can remember that when alloy wheels first arrived for one wheel manufacture recommended that wheels had a finite life and had to be returned to be exchanged on safety grounds.
The roads are shocking. Like a warzoneHi , I don't believe that alloy wheels are now not strong enough in the first place for UK roads with all the pot holes in them.
10 years ago the pothole problem caused issues but in 2022 the roads in certain areas of the UK are now dangerous.
They all use it on wheels that are a bit leakyThe rubber 'goop' on a paintbrush is often applied on old rims having second hand tyres fitted There is a used tyre fitting place next to my mates workshop on an industrial estate , I have seen them using it .
Not something most of us would use I suppose , but it depends![]()
