Hi all looks like I’m likely joining the failed gearbox gang
I have a manual w204 (2012) with no way of selecting reverse at all! Second gear was fine driving back from dropping the boy off at nursery. But on moving the car next day second gear became stiff altho it does select when engine on and off but still sticky/stiff. I’m assuming this is a likely the fork breaking issue inside the gearbox. Before I continue I’m the least clued up person from reading this thread so apologies if I come across as thick haha. So my questions are if anyone can help with is… firstly I’m assuming gearboxes after 2013 are less prone to this failure or better than previous years hence recommending to find a second hand of this year but in doing so how would you go about this? I was thinking you would have to replace with the exact gearbox number to save issues but in changing year of gearbox is that going to make that impossible or would any past 2013 gearbox be ok regardless as it’s a swop out job?
I had a quote from a transmission specialists saying it’s likely the fork snapped so to have mine stripped repaired reinstated and new clutch/flywheel I’d be looking at £2300. I’m going to guess that the repair will be a make shift part as the spring is non existent (gold dust) What actually is the part number for the spring that’s required? If changing for a 2013+ gearbox would you then need to buy a gear selector if that year to suit?
Once again sorry for the questions some maybe stupid but Iv never dealt with a transmission issue or how it all works
Thanks guys
