C180 w202 srs problem
Justin28861
Dublin
C180 W202
The srs light came on then went off after 2 minutes, now it is on permanently, any ideas on how to clear it PLEASE:dk:
Most common cause is the cabling under the front passenger seat, try this 1st:
The cables can be knocked out of the yellow plug, unplug it from the seat itself, flip open the yellow 'door' and check the wires are touching the pins. - very easy to fix.
If the warning light is now on, even if you cure the fault the light will need to be extinguished by a diagnostic computer.
Though as Killerhertz quite rightly says regarding the passenger seat wiring, it could be cured just by unplugging/plugging back in the plug, but as the light will need to be reset anyway you are better off getting the codes read and see what they say first, also be aware I would say a good 95% of SRS faults on a 202 are to do with the passenger seat, though in my opinion most turn out to be a fault with the occupancy sensor in the seat, requiring replacement.
Cheers but I can't find any wiring under passenger seat. think I will just pay for it to be done, it's up for NCT in April anyway. Thanks
