Does anyone have pictorial (worth a 1000 words I think) disassembly instructions for the rear view mirror on a Mercedes C200 Part number : A210 810 0317
This issue is that my red LED in the rear view mirror assembly is no longer working; the immobiliser circuit imbalance then can prevent the car from starting.
I would like to mention for those that are stuck as I was that there seems to be a combination of switching the ignition on waiting, switching off the ignition, turning the immobiliser on and off and re-syncing the key fob, (basically about10 minutes of random messing) and you can eventually get a single green flashing led light on the door handle. The car will then start.
I can get the entire mirror assemble off the car ceiling as this is just a sprung loaded clip, pulling straight down or slightly towards one of the doors does the trick. Don’t pull too far down as there is only a short wiring loom attached to the mirror, this has handy male/female connector. Its worth saying that the car will not function at all without the mirror assembly plugged in and it is really difficult to get it back in place as the sprung loaded clip is very strong. To do this I located the left hand side of the clip in place and used a large flat screwdriver to push the other end of the clip back, then a big push from underneath and hay presto…wasn’t easy.
What I need to do is replace the red led but would like to know how to disassemble the rear view mirror unit without damage, also if anyone has the rating for the replacement led that would be fantastic.
