c200 sport coupe
potter1976
Hi all I have a c200 with a sequencial gearbox won't select any gear anyone had this problem before. Thanks jon
Hi there have you changed the oil in gearbox? After time oil breaks down and that's when this happens, can you select gears using paddles
Its not a paddle its gearstick still with auto mode or semi automatic checked all relays checked wiring to ecu all ok on dash got transmission fault will check oil see what its like cheers
Should be the colour of cherry aid
Cool will look tomorrow is there some kinda dipstick where would that be located also where is the gearbox ecu located on car cheers
