vieroli
I have a C270 CDI that I bought new in 2002. Initially in its first year, but only occasionally the car would lock in a gear when you step on the gas and it shifts down. You would then have to stop and turn off the ignition, then start again and it would be okay until it happens again a few weeks later.
The computer at the agents did not show up the fault and it was not fixed. This year the agents said it was the air mass sensor which was replace twice, but now the car revs high in each gear before it changes to the next. It would also shift down, when not necessary. This happens every day, although it may not happen when the car is cold, but after some time it would start again.
The agents say it is a mechanical fault in the gearbox as it is not showing on the computer.
Is there anyone who can give me advice in this problem?
