Hi guys looking for some help again.
I changed the fuel filter on my C320 CDi yesterday as I have done before with no issues, however this time after a short time the engine warning light came on and the engine has no power as if it may be in limp mode???
The filter was primed as usual as I have done before but this time the engine is flat and won't rev 40mph max and takes for ever to get there!
I checked the plugs I had to remove to get access to the filter and all the wiring seems good and tight.
Only difference this time is I may have had the ignition on, will this have caused a fault with the Air Mass Meters I had to unplug?
Any help will be greatly appreciated
Thanks in advance
Thanks in advance
