crockers
- Mar 30, 2007
- Location
- North Wilts
- XC60 MY2014 SeLux Nav plus lot and lots of toys...
Do DPF ruin the economy? If so can they be removed and the ECU reprogrammed?
I thought it was only when they go through the regeneration process that they use extra fuel.
I don't go with diesels needing a long time to give best MPG, or them using significantly more fuel in cooler weather.
The latest Cdi give shockingly poor mpg figures.
It takes a least 30k miles to bed one in, and more.
Looking at some of the posts here, and other posters they are not terribly great, however they give a performance in terms of acceleration and top speed that a diesel engine designed 15 years ago simply couldn't achieve.
I also believe that now, more than ever, the engine is designed specifically with that test in mind. Engines, transmissions are all designed to do extremely well it that EU test, but maybe now to the detriment of real world driving.
Having had quite a number of brand new cars I can't say I've ever noticed a change in economy after the initial acclimatisation period.
I suspect economy improvements are down to drivers adjusting their driving style to suit the car.
According to the OBD Mrs DM's car delivers the same economy as it did when she got it.
I think new engines are less efficient to give lower emission readings in tests, however in normal driving this requires greater use of fuel to overcome the inefficiency.
I agree that modern direct diesel engines are giving greater output than previously, but that is mainly by finer injection and more fuel being delivered, however if just travelling with the traffic surely this greater output isn't being used, unless all traffic now accelerates more quickly, which is possible.
I filled up on Thursday evening and the tank gave 39.6mpg measured brim to brim over 627 miles.
So that's an old ultra reliable indirect sludge burner giving 20% better mpg than a new less reliable, high efficiency Cdi.
I'm really struggling to find a good reason to change.
Normally about 60k miles or until they started giving trouble, which with the Chavalier and in particular Volvo was well below that figure.How long did you keep them for though?
You forgot cup holders...The way the bulk of people buy cars and finance them (and I am going OT here) forces them into a change (PCP). People buy new cars because financially they are tied into this.
Now stay with me on this one, and I know this is conjecture, but nothing sells a car faster than powerful outputs and the promise of better MPG, so they design an engine to pass the emissions test, score well on the EU tests, and out of the test parameters the engine is mapped to deliver a lot of power. How relevent is that, very, as car makers fight for your business when your 3 years is up, after 3 years, their warranty is up and the financial obligation worse case suddenly shifts from manufacturer, to customer. You're car doesn't come from that era as durability was seen as a much bigger selling point, than 1sec faster to 60.
Have you seen Mercedes enthusiast this month, C63 vs a C350cdi used vs new peice. Both cars once factoring in total cost breach £800pm and the C63 over 1 grand a month.Anyone for a C63?![]()
Emissions and fuel economy are directly linked, the more fuel you burn the more Co2 you produce, so the targets are designed to reduce those emissions.Emissions and fuel economy are very different things.
Emissions is something the EU gets all flustered about where as MPG is something an owner is more concerned with. The EU does not give 2 hoots about the MPG in a particular car as long as the emissions are low.
So if fitting a DPF for example reduced emissions but also reduces economy by 5mpg then so be it. The EU hits its carbon target.
As stipulated in the target CO2 outputs, the reduction in available crude oil and that engineers like to make gains, not losses in technology advancements.Then there is the view that diesel cars must produce better MPG year on year.
But at the other end. The 6 cylinder 3 litre engines from BMW, MB and Audi the goal is not to produce the engine with the highest MPG. It's to produce the most powerful car.
You simply cannot take an engine, squeeze more power out of it and then expect to get the same if not better MPG. It doesn't work like that.
Compared to what?
It is if you are going to be lazy, but if you improve efficiency then it's not so at all.The more power you want, the more fuel you have to burn. That's physics right
Your statement is wrong on many levels, I'll answer some.
A calculation using (mpg/12.2) * 620 will give your Co2 output per 100km for diesel. Note the direct relationship between fuel burnt and Co2 output.
Who wants an engine that is dirtier less refined and uses more fuel than the previous generation?
the new crop of engines is producing worse mpg figures than previous generation engines.
DPF were introduced because of public perception of diesels being dirty due to particulates. This stemmed from inaccurate press, but the public lapped it up....they only have themselves to blame.
Of course removal of an exhaust restriction will assist performance and economy and removal of the super dose of fuel required for regeneration will help as well.
and with the hateful 7g box offering long gearing with a small efficient engine. I'd say that E220cdi I was loaned had the same power as your car (170bhp approx) and when driven gently (speed limits) it would give a 43mpg in the cold on a tight engine. Witha 7g thats going to be nearer 50mpg
