Anyone after a C36 AMG Engine ?
http://cgi.ebay.co.uk/W202-C36-AMG-...ryZ10398QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
nice! Wouldnt mind building that into a little C180 sleeper![]()
Well it's at £1 + £100 postage.
Would be a good buy but then it'd need fitting, although it comes complete with ECU and loom.
Fitting might not be a problem
I'll keep my eye on it!![]()
I might be totally wrong here, but im quite sure only the very early c36's used to have that design rocker covers. Im quite sure a 1997 model would have had one like this
If that is the case, id trust nothing the guy says. These engines are very expensive to repair, Mr Walker was pricing a rebuild ofr me a while back.
I believe the engine pictured is an M113 block.
The block, crank and rods would be ideal for a turbo conversion.if it needs expensive work, that I'd be able to punt it on.
The block, crank and rods would be ideal for a turbo conversion.![]()
Seems risky buying from Germany though. Why is it listed on UK ebay if it's in Germany?
The C36 compression is too high but that could be taken care of with new pistons. The cams are also not ideal so you would need a 320 head.
I thought the rods were stronger but I could be wrong.
A 3.6 with the diesel crank, forged pistons and two turbos would be quite a beast.
