c36 m104 noise
horgantrevor
w202 c43 & w210 E220 CDI estate w219 W221
hi i was out the other nite and the hose for the rad from botton right of rad to temp stat underneath rubbed of the powersteering pully and i had a leak only found out when i got home but on the way i heard a squeak which got faster the faster i went also the water light just came on about 100 yards from door so i drove in and parked up
in the morning i opened the bonnet to find low on water and leaking hose
i fixed the hose and filled the water up
but i still have squeak it sound like its the water pump to me if i spray grease on the shaft it quiets up for a small while but i can hear what i think is bearings their is also a hiss like bearing rolling weard noise but when the noise returns its a squeak
any ideas
thx
I'm not an expert on the C36 as I have a C180, but my water pump suddenly stopped working and caused the belt to snap. If you have an inkling that it is the water pump I would replace it rather than chance your engine overheating due to the fan belt breaking.
no belt has snaped
water pump looks ok and engine is not overheating when driven
has me puzzled a bit
Any lights illuminated on the dash? I had a warning light and then it went while I was on the motorway, pulled over so no damage was done.
