C43 amg a few fault questions with codes
horgantrevor
w202 c43 & w210 E220 CDI estate w219 W221
Hi I bought a c43 1998 the other nite she is now parked up in my garage
The faults I have are only a few I checked her on star and these are a few pictures of the faults
And help would be good
pic
Fault in communication with the passenger front door control module. Behind door panel, check wiring to it and also connects below the passenger kick panel.
Check you have no water ingress in the passenger footwell maybe ?
Other fault is a Air Bag fault, would have to look up which one mate
im sure i remember it said it was driver side airbag
i found water marks behind the door card s on both front doors i think i will just replace them
the airbag has me stumped but their is ohm logo their maybe the resistance is too high in the circuit
she needs a bit of love but im the man for the job
a few more pictures
Very nice Trevor. Possibility the photo's don't do it justice. Enjoy
yes i had just picked it up drove her half hour removed plates and put her to rest i havent been back to see her yet im afraid to start ill never stop
Trev you finally got one then :)
Emergency tensioning retractor ign. circuit Driver.
I would of thought that it would seem to indicate to me that the drivers side seat belt pretensioner is at fault or the connection to it, though whether drivers side means left or right I don,t know as STAR is after all a German programme.
As the seat belt pretensioners are in the seat belt reel of a 202 it might be worth looking here first in the quest to extinguish your SRS/Airbag light.
Thank you andy yes I thought it might be that but I'm going to strip interior and check every connection and clean then put back
I'm not in any hurry to drive her I just want it right
Ill keep you posted on any updates
Hey trev finally got C43 good luck hope you get the faults sorted.
ya i called out today had a bit of time to really look the car over
rust ok on surface under the car and rust on a few changeable items
the alarm siren needs changing
the passenger wiper motor needs changing
fog lights need new bulbs gone yellow and the xenon bulbs need replacing
i think ill change the bonnet its me being fussy
as for the interior all the leather needs a good clean and im going to dye the white leather again
steering wheel has had the white leather replace with black which is good as it never lasts
booked in next week for the whole under neath of the car to be cleaned and waxoled and replacing all bushes and a few arms
im going to then replace all rubber gaskets on the engine , rocker , oil cooler , ect
new belts and waterpump i always do it on a car im going to keep
its a start i am looking for a rear blind with switch im going to make the loom and i have the trim
i had a go today to change the passenger and drivers control modules as one of the faults showed that as i have a few spare and no joy it must be the connection in foot well
ill keep you posted thx for the help
trev
Changed headlight motor today and alarm siren as she being stored I cleaned all the inside
I fixed the fog lights which were blowing fuses due to water in one in going to replace both crystal clear ones
I only just released the car has auto dim rear view mirror and illuminated sun visors
I got the sunroof running perfect after some TLC
But it has a common problem the inner cover slides when driving open or closed a clasp must be gone
It's getting their a decat in soon
And full under seal this week
