C43 Cooling Fan Issue
Also to add that the indie I spoke to said they would run check whilst fan running & thought it something to do with A/C Compressor which read in this thread.
I love the car but tbh would sell it if I could! Things like this really irritate me & take the gloss off a otherwise decent motor!
Be interesting to hear what your Indy mechanic says... mine was hesitant to change the A/C compressor as no fault found. Very much the same, love the car but its so irritating, more so when parking at night when it quiet.
When I dropped mine off for the fuel issue recall, they specifically told me its wasn't to do with the fan, its like they were expecting me to mention it.
What I thought was amusing, when I picked mine up, a guy parked next me (similar model) I asked if it was due to the recall, he said it was something to do with engine fan staying on... told him good luck.
Yeah he's got no hope! Will report back on Indy as hoping to pop it in this or next week
So went to Indy & they ran diagnostic check but said all parameters were OK
Just to add my wife's C43 has literally started to do it as well this week! Also at about same mileage mine started!
Both times that this happened with mine it was cleared by a 75 mile motorway run.
Funnily enough mine cleared the first time after a run of about 60 odd miles.
My daily to work is only 7 miles each way
Mine also has stopped, daily run is around 20 miles, but happened to have a round trip to Southampton and back and all is silent.... still expecting it to be there when I park.
I've just started having this with my 68 C43 too after 2 years of not having it so it can't be a "quirk" of the vehicle.
Did 2 long journeys and fans started going crazy.
Didn't use car for 2 weeks.
Did 2 long journeys again and same issue.
Did 2 short journeys the following day and it didn't happen.
I noticed the engine temp was lower for the short journeys, don't think it reached 80C so seems like that could be related?
Did also notice the battery isn't full charging either since this began.
Just to update on this, took it in for Service this week and mentioned this. Don;'t know what they did but it's resolved! Bit annoying the Mercedes staff don't tell you anything but oh well.
Probably a software update was done.
Hi All, just set up an account to respond to this forum, been having the exact same issue since start of Dec on my 68 plate C43. Was serviced by MB, they said its not a problem no issues. Didn't believe them so took it to an MB specialist here in Belfast and they noted there was no fault with the AC fan control unit, but recommended I take the car to an auto electric specialist incase its a wiring fault but noting something is definitely wrong. Just off the phone with the auto electric boys, since leaving the car in this morning, and they've found that there is a fault with the sensor that tells the car to complete a regen of the OPF.
So the car is essentially running a regen 100% of the time now, which causes the fan to run and as the car burns extra fuel to burn soot from the OPF filter, this explains the loss in MPG. Its 80 quid for the replacement sensor. Will update once works are done to confirm the issue is resolved, but for those still having this issue I'd advise taking your car to an autoelectric specialist and ask if it could be an issue with the car constantly attempting a OPF regen.
Just to chime in on this too. I've also started to notice a fan overrun after parking up. Only seems to have started in the last few weeks when daily weather temps really dropped. What's weird is it's not consistent. I can do short journeys where the coolant temp doesn't get above 65 deg C and the fans will over run once parked up. Yet after longer drives where coolant temp has reached 93 deg C i pull up and fans shut down with engine straight away? I've not been monitoring mpg so i'll start to take a look at this. I'm due a 70 mile drive on Sunday so will see what happens then. I've also noticed a strong coolant smell when getting out the car after a drive but don't know if this is normal. Coolant levels in both reservoirs are fine and the car had a B service only about 3 weeks ago (Fan issue was happening before the service). I also keep getting the '12v see owners manual', error message - prob doe to the fan overrun and a weak battery - again no idea if these are related. I'll give it a scan tomorrow and see if i've any stored codes. If i find anything i'll be sure to update
So having just fixed my 68 C43 before Xmas, i've just got a 21 C43 and lo and behold, as soon as i drive it home, same issue!
Hoping it's a quick diagnostic fix like last time, will take it to the same dealer but they don't have any appointments for 3 weeks. It was serviced a few weeks prior annoyingly.
If they do fix it again can you ask them what it was. I scanned mine and no fault codes exist. It still seems intermittent. I also kept an eye on mpg but it seems normal around the 30 mark give or take.
Just curious to see if it might be the sensor for OPF that was mentioned earlier in thread. Mine you at £80 a pop + labour surely they’d be billing you for that kind of work?
Yep will update. I spoke to the dealer i got it from and he's arranged for a different Mercedes to collect it next week so hopefully will know soon.
Hard to tell if it's affecting the mpg as i've not done a single journey since getting it without awful traffic. I did notice the full tank range estimate is awful but i remembered that was the same with my previous car when i got it and it soon changed when i started driving. At the moment it's 250 miles whereas i was typically getting 450.
Uneventful update, they have the car but have been unable to replicate the issue and no error codes. It hasn't been happening as frequently with this one so I did suspect this might happen.
Of course I'm not expecting them to be able to replicate it as they're just leaving the engine on at Mercedes but I did get them to collect it from me which was a 25 minute motorway drive so I'm surprised it didn't happen after that.
