C43 fault code
horgantrevor
w202 c43 & w210 E220 CDI estate w219 W221
I I fixed my air bag fault as some twit running aftermarket speaker wire pulled the connection of the seat belt tensioner
Now to my last fault
It seams the EIS may be playing up this is the fault code see pic
What sometimes happens with W202's is that water gets into the rear door window motors. This plays up the Can bus.
Try disconnecting the rear window motors and see if the faults go away :thumb:
thanks guys ill have a go
sorry for the pic being sideways
i found out yesterday if i move the large set of block connections in foot well connecting the driver door i got it to work so im sure ill be fixing that every thing works on it but every now and then it looses one touch
as for the front passenger door only the seat control works and folding mirror no window or glass in mirror movement
ill have a go monday all going well
its amazing what you find when you tear apart a car i know know it had a back window at some stage
its coming along nicely and i know almost every inch of the car all ready
if i dont get the EIS issue fixed i have a ecu key eis steering lock from a c43 all matching ill swap over and it may fix it
