C55 aircon condenser
LabourOLove
Manchester
W203 C55 AMG
Good evening all
I need to replace the air conditioning condenser on my W203 C55. It looks a fairly straightforward job having read a step by step guide written for non-AMG W203. Can anyone offer advice for replacing the condenser on a 55? Are there any differences in the procedure that I should be aware of?
Cheers
Ant
Hi
'Non AMG' 203's have a completely different front end , as you probably know the AMG front end is from a CLK , the front grille stays behind when the bonnet opens , it goes up with the bonnet on non AMG . There are two small 'radiators' in that area (transmission cooling) , not sure if they will be an issue.
I have not done the job myself but once the fan is out of the way I can't see it being much different from what you have already read .
Reason for replacing it ?
Hi
Hi Pete
Thanks for that. I am aware of the differences between the 55 and the regular W203.
I found a decent step by step guide on Pelican Parts so I guess I’ll follow that and see if any additional parts require removal along the way.
The condenser is doing its best impression of a colander with all the holes in it. I was tempted to go with Nissens for the replacement. Do you have any experience of this brand?
Cheers
Ant
Nissens are good
Condenser job is a pain due to the routing of the pipes apart the rad pack, meaning you have to separate everything to get it off. It's not hard just a pain.
Nissens are good
Thanks for your input.
Do you take the rad out first followed by the condenser or do both come out as one?
Hi, i have the same issue with mine w203 320cdi. I had a nitro test which found a leak in the condenser. I have seen some on autodoc but not sure which one to get. Does anyone know where to find the oem number?
