golden1245
- Sep 6, 2011
- 1999 C230K Sport
So I put aside the entire day to start replacing my brakes and rotors on my w202 c230k. Everything is going well, caliper comes off, pads come off, spray everything with brake cleaner.
Now I'm about to unscrew the big caliper mounting bolts to get the rotor off and the damn things won't budge...at all. I spent a whole hour in every imaginable angle in order to get some muscle into breaking it loose, even tried using a toggle nut wrench but I didn't want to strip the hex.
I didn't use what they would call a breaker bar, but either way I think they might have seized, it's been 5-6 years since i've last had a rotor/brake change.
what do I do? Just follow the the remedy I see every where on the internet regarding stubborn bolts? spray with penetrating fluid and heat with propane torch, repeat until loose? or is that not a good idea for this car? Please help! Thank you in advance for reading.
