camber adjustable ?
I believe that the camber is fixed so not adjustable. The toe is adjustable.
You can buy adjustable camber arms but they are expensive.
thanks what it is i reversed on to a high kurb last year and bent one of the rear arms i replaced it , but the inside edge is wearing on that side ,so i may have bent the thurst arm as well or the toe is out , im going to replace the arm then get the rear tracked
