My wifes car(C200K ,52K miles) has developed a rattle from the camshaft actuator, If I unplug the wiring to the magnet it stops ,so pretty sure it's that. Question is do I get it repaired at £800 + or will leaving it cause major problems in the future.
Also discovered the oil in the loom problem at the same time, will fit modified part this week and check ECU.
Thanks in advance
Thanks in advance
