It can be changed but I don’t know the part number . I bought new Lemforder arms from AUTODOC when I did mine because it was DIY , if I had to get someone to change the bush for me it was probably the same cost as me buying the whole arm .On the cross member numbered 300 can the bush be swapped out rather than replacing the whole arm?
If so does anyone have a part number for it?
Bit confusing the vin diag shows it as cross member. I had the front lower control arms replaced yesterday, so I'm guessing you are correct. thanksIf that's the upper front control arm, look up Corteco 80001825. The price seems about the same as the whole control arm and you get a new ball joint thrown in.
Fine, but do you need a big press to remove and refit it??
My indie Alex Crow will be fitting these and they have a press to do this. txMercedes has specific control arm bushing tools that you can use in place of a shop press. I had them for my W210. You might also be able to get away with using a long bolt and different sized sockets if you're creative enough.
Thanks - is that replacement with MB arms or lemforder?Replace the whole arm. Its often better value.
LemforderThanks - is that replacement with MB arms or lemforder?
