punjabi
300TE - under the rear seat, the central locking pump has a black connector where the vacuum tubes fit, any idea how to disconnect this from he pump body without breaking the tubes?
2 ways.
1) warm up the pipe with a warm air gun
2) cut it off close to the pump, then cut off the piece of pipe.
Warm up the pipe to refit, not too hot
I want the pipes to remain intact - just the pipe connector unit to be removed from pump in order I can replace the pump and re-connect the unit.
If it's like the later one with the valve block, you prise open the catch in the middle to release the block.
This is the photo of the pump with the plastic block where the yellow pipe tips are visible - how do you "prise open" the block from the pump!?!
