Hello! I have a C200 and I want to change the cooling fluid. Can someone please post a how to (with pictures)? The cooling fluid what is your adveci? From the dealrship? Water with antifreeze?
Thats a fairly tough ask unless someone has already posted one or is about to do it...
All you need to do is find the drain plug on the radiator, drain the water out... there will also be a drain bolt on the main engine block if you want to be really thorough..
then refill with 50% antifreeze to water... i use the comma blue stuff..
