Cheap Supercharger on Ebay ?
Howard
MB Club Veteran
Toad Hall
2018 C63 Wagon / CLK430 / A150 / VW Pink Floyd Golf Cabriolet
Sp!ke said:
Shows up as ... A2710902080
TURBOCHARGER
EUR 1,291.53
So its a grand new - which this looks .....
gotta be worth buying if you've got a 230 komp ..
p.s. auction is nothing to do with me by the way :D
If the part could be identified as being for the m111(?) engine then I would be interested.
Can you get someone to look it up off the part number Graham ?, its in Sp!kes post ......
EDIT : here we go 'A2710902080'
good luck
Hmm, I have done no investigation, my funds are low, only an hour to go, but I am still tempted.
Bidders are leaving it late as usual.
it is for the w203 in case anyone was wondering.
EDIT: this is for the w203 sportcoupe, C230k, models beginning with WDB203740, M271 engines.
second EDIT: that was for 2180, not 2080! Hang on :)
that kompressor unit should work in these models:
C200 kompressor : 203742
C200 kompressor : 203242
C200 kompressor : 203042
CLK200 kompressor : 209342
CLK200 kompressor : 209442
C180 kompressor : 203046
C180 kompressor : 203246
C180 kompressor : 203746
Ive seen these come up a few times, out of intrest is it possible to modify a CLK200 engine and add one of these?
R2D2 said:
Yes or a C200 like mine, all you need is all the fixings, pulleys, new ECUs, and about £2k and someone confident enough to do it;)
it'd probably be cheaper to swap the C200 engine for an S500 engine.
I Like this thread :)
