Clay
You can use decontamination products, typically solvent based, citrus based etc to strip off tar, metal impurities etc. more you take off less to remove with the clay.
Used an iron/fallout remover recently and was surprised how much metal there was on the paintwork... some of the products bleed, that is change colour when they react with metal impurities. Looks pretty cool and gives you an idea of where to pay attention in future.
You can have lots of steps to cleaning but as with most jobs right tools/product helps loads. You can spend as much or as little as you want.
For example 500ml of the product that changes colour when reacting with metal circa £10 a bottle.
Another product that does the same job but doesn't bleed £13 for 5 litres and you dilute it down.
Well worth reading up a little on Detailing World, be warned I looked purely to get advice on how best to use Autoglym Super Resin Polish and I reckon £500 later I've only just scratched the surface with buying stuff and trust me that's nothing!
^^^^^Well said. It seems that EVERYTHING gives a deep shine that lasts forever. Not. The key is preparation before trying to make it shiny, it seems.
Totally...
Can you explain that to my Mrs?!
She loves when her car is clean but doesn't understand why it takes time to do all of the processes.
SpoonJar, does the car shampoo make the clay quite sticky? I once used clay with tar remover and it dissolved the clay, in hindsight the solvent in the tar remover wasn't a good idea. Doh!
MDC250
"Can you explain that to my Mrs?!
She loves when her car is clean but doesn't understand why it takes time to do all of the processes."
You are most definitely on your own there………good luck.
Don't forget; use small amounts of clay and take a new piece for each panel, or fold over to get a clean surface. If you drop the clay, bin it.
I've had no problems with the clay bar becoming sticky or anything like that, but like you said it was probably the tar remover.
I find it's a good thing to keep the surface as wet as possible or the clay can drag across your bodywork and leave a mark.
