Not sure if this is the best place for it so please feel free to move.
Any of you owners with the Thermotronic had any issues with the system getting confused, one or two people have seen the same thing as me and I'm just curious.
I've noticed the problem in my SLK but I've not had enough time with any of the service cars we have with the system fitted to test it out and i don't like to use customer cars for it, basically you can start the car up from cold fine then after 10-15 minutes one side of the car can steam up and its normally the passenger side but can just as easily be the drivers when it wants to.
The system normally sorts itself out after a few minutes or you can cycle Auto and that normally has the same effect.
I've leak checked the car and can't find anything, pretty much all of the roof seals have been replaced and alignments checked, run the diagnostics on the system and as far as its concerned everythings dandy.
All i have noticed and a quite a few people with 171's have complained about the same thing is a shot of cold air when turning left and again we have checked literally everything we can think of on the cars and cannot find the source even using a pressure washer and compressed air to get some pressure on the seals, it does tend to go away after 30-40 minutes or if you cycle the door a few times so that suggests a seal but they all check out fine and all the door alignments are good, it actually seems to be above the door anyways more neck level but all the roof and window seals are in good working order and correctly aligned.
Personally i think the 2 are unrelated since the misting can happen at any time, any ideas you guys may have will be much appreciated as Merc tech are as baffled by it as us.
