the large nut needs to be undone. i believe it is 36mm, you will need a solid spanner. the best way is to put the spanner on and tension it slightly, then hit it with a hammer!! all this is done with the polybelt fitted to make it easier. once freed off the nut will easily unscrew, but take note....
IT IS A LEFT HAND THREAD, that will be all.
