Mercedes CLK 430 2000
Problem:- Limp mode
This is a follow on from http://www.mbclub.co.uk/forums/new-member-introductions/163440-introduction.html
Im hoping to keep this thread alive and updated regularly until i solve the problem to help other users.
I have the car booked in for diagnostics tomorrow.
so far the clk is in limp mode with no dash lights illuminated.
Problem:- Limp mode
I've checked under the passenger side carpets and it was covered in oil
I had wiped most of it up before taking a pic.
I always thought ATF was red rather yellow.
I wasnt 100% sure where the oil was coming from so removed the white metal plate to reveal an ecu (transmission?)
All the wiring and pretty much everything under this plate was covered in oil.
Im assuming that from reading other posts/forums that the plug on the underside of the transmission is leaking and wicking the fluid up into the car
Anyone know what the thing in the top right of the picture is (three cables going to it)?
If the ecu is fried is it a fixable part? im handy with electronics so can replace pcb components or would it be easier to replace?
im yet to get under the car to check the plug on the side of the gearbox but will take pictures when i do this.
hopefully ill update more tomorrow.
let me know what you think.
Regards
Dan
Regards
Dan
