Hi folks, my first post on here so be kind.
I have 1998 Clk 320 coupe.
About two weeks ago I noticed the abs bar warning lights come on. It drove fine so I just left it. I read a few posts saying it was due to a build up on the censor etc.
Anyway, today after a cold week I had been driving for about a mile when the 'battery charge' read on the dashboard, but worryingly the power steering seemed to cut out!!
It was drivable so I managed to drive the rest of the way to work where I put the battery on charge.
Question 1 - top right of the engine bay I found what I think is the positive connector, the nip which is best described as a rounded large bolt about two inches further in, is that the best neg port?
Anyway 10 hours later I started the car, it started fine but exact same problem!
As I was driving it was blowing cold air, wouldn't warm up, so I turned air off, radio off etc an for about two miles it drove better, steering loosened up a little.
But that's where it ended, all of a sudden the lights went out an I lost power.
I crawled to a lay by and left it put. Enough battery power for radio and lights but it won't start, I've tried jump starting it and nothing.
From my very inexperienced views I have done or noted the below:
There is no spark when I connect the terminals, not even a direct cross of +/- is this likely to be the two connectors? Hence why it is not charging or allowing a jump?
Also silly I know but I can't actually find the battery! Just them two connectors I was tying to describe!
Points I need to know really. Is this likely to be a battery problem or more serious of power steering pump etc?
Any help would be much appreciated as my car is currently sat on a bypass ( in liverpool!) so might not have any wheels left if I don't fix it soon!
Adam
Adam
