CLK Road speed tapping noise
rufus357
So I've got this annoying road speed tapping noise. Its intermittent, doesnt occur at low or high speeds, is worse when left side is loaded (roundabouts etc). Its not the wheel bearing as I've changed it, its not a stone in the tyre.
Any ideas?
Any ideas?
Broken spring ?
The clips are available from MB bit strange to fit as they are basically tapped on to little pegs attached to the transmission tunnel. I have some spare in the bits box for when another one lets go.
Worth backing the clip up with a large zip tie as well .
Brilliant - thanks for the replies - will report back when Ive checked it
