CLK Starting problem
drew.mccullough
hi all
I have a CLK 320 that is having a problem when starting. The engine will not start but is trying to - the battery is not flat - and sometimes the engines feels like it is going to grab but ten doesn'r. Anyone any ideas - or need any more info?
Thnks
Drew
drew.mccullough said:
hi all
Thnks
Drew
When was it last serviced and what mileage is it?:confused:
It could be many things, but plugs and fuel problems are the most likely.
Just been thinking about this and as Brian says a little more info may just help us help you.
My bet says crank or cam angle sensor. You need to have the codes read.
Crank sensor would be my bet - especially if after 10mins and over 90mins it will start, but won't after 30-60, happened to me - nightmare! - £150ish at an indy
