CLK W208 Alarm Going Off
sammo65
Fareham
CLK 320
Need some advice my 2001 CLK W208 320 has started setting off the alarm. Tends to happen about an hour after locking the car. It fortunately stops when I open and relock the car, but am worried it may get worse. Is it the battery needing replacing as voltage dropping? or need putting on star and resetting? I even read about spiders inside the car? Can I remove a fuse if it becomes a total nuisance or activate the towing button? Welcome any help/advice? Thanks
Wow.. this brings back memories! :D
I had a 2001 CLK and I had this exact thing happen to me over a few nights.
Car alarm would randomly go off late at night.
I'd go out and open and re-lock the car.
This would happen over about 3 or 4 nights.
Couldn't work it out.
Few days later, I found a dead spider on the rear carpet below one of the motion sensors and a web over the motion sensor.
Not sure if incy-wincy was the cause, but the alarm did not go off again.
:D
Try turning off the internal sensors for the night, there is a button on the dash for this. I used to go through a week or so of this every year due to a spider or something in the car.
Is that the on/off button with the car being towed away on it?
IIRC yes, can't picture it right now but I think the button can be rocked up or down to disable tow or internal sensors, or both! It will light up on the appropriate setting.
