CLK windscreen wipers not working 🙁
thebusman
Gloucester
Clk
HELP... I have an 06 CLK with wipers and washers now not working. Any idea which fuse to check? I can't find the handbook? Is there only the one fuse box on this car, or are there more?
If you “pop off” the end panel of the dashboard (visible when the door is open) there is a fuse board and should be a folded up fuse chart ?
Anything fuse info wise in the glovebox manual ?
Bonnet closed properly?
Had similar problem, wipers only worked on wash. New multi function stalk, I believe they are known problem. check fuses first, it's cheaper.
Sorted dry fuse cleaned up.. Cheers...
