mwstewart
- Sep 28, 2008
- Location
- London
- CLK63 Coupe, Ferrari 430 Spider, BMW E46 M3 Manual Coupe, 500+bhp Fiesta
I haven't yet fitted the Dension 500 Gateway so last night I took apart the CD changer to see if I could repair it, to use in the interim. The screw securing the changer to the glove box was missing and some of the case screws had seen a screwdriver in the past, so obviously this is not a new problem.
With the outer cases removed I plugged the changer back in to the car and noted that the mechanism seemed absolutely fine. I don't think it has seen much use. I let it cycle through a few CDs and used air to clean the lens and the fibre optic connection, reassembled, installed, and it is fixed.
The only problem now is that the version of the Gateway I have is the 'single FOT' version, which means it doesn't have a fibre pass through; there is a 'dual FOT' version available that acts as a multiplexer to enable the original CD changer to be retained and operational. I'll have to get one now!
