SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
i've been steaming up over the last few weeks. aircon now on a lot more than usual. dark, cold, wet nights are to blame.
In both my W203 and wifey's new Honda Jazz it's been impossible to turn the a/c for the last few weeks.
There is something curious about the Merc system in that you can turn it off and the windows stay clear but then suddenly mist up a few mins later.
A comment in another thread from an indie indicated that on a car he was working on the a/c compressor clutch stayed partially engaged when the a/c is turned off. The percentage of engagement can be changed using Star.
If this is the standard way the system works it would certainly explain what's happening in my car. On Mrs R's Jazz, turn the a/c off and the car just instantly steams up.
Hey Russ I'm new to climate control, seriously do you leave it on all the time? I have a clk and it says AC on the switch is this climate or aircon?Why are you switching the air con off?
Mine is on permanent, it is climate control so let it do its job and leave it on.
Russ
It's typically 3C and I've certainly been in trouble on start-up when the previously wet evaporator has dumped moisture into the car but the a/c hasn't worked.Agreed that there is no substitute for de-humidified air, but don't forget that most AC compressors will not engage when the external ambient temperature falls below +5c.
This is because there is a delayed shutdown of the compressor
Interesting thread! As some others have said leave the climate control on - I did for 4 years in my W211 E 320i and though occasonally I switched it off it didn't seem to affect the fuel consumption.Yep, leave the aircon on all the time, unless I have the windows open in summer.
with what??There's a long thread about this here: Google Translate
It seems there's an "afterblow function" designed to dry the evaporator. It can be switched off with Star.
with what??
