Do you have exactly the same "Tirefit"kit as I have though (photos above)? My car never had a spare wheel, collapsable or otherwise as the battery is in the boot. My compressor doesn't have the correct connection for a tyre valve, you only appear to be able to connect it via the bottle with the liquid in it. In other words: Compressor > Bottle > Tyre valve. I can't see a way of connecting the compressor directly to the tyre valve, which is why I was asking if I was missing anything, or whether this is just how it's designed i.e. you can't pump up a tyre in the "normal" way with this kit?
