crockers
- Mar 30, 2007
- Location
- North Wilts
- XC60 MY2014 SeLux Nav plus lot and lots of toys...
How cold does it have to get before diesel is affected? I believe it can go waxy at a certain temperature....
Depends.
Distributers put more of the anti-waxing stuff (you can tell I'm an expert, eh?) in during the winter months. So it depends who you buy it off and whether you filled the car in the summer and then didn't use it....
Depends.
In the fuel strike of 2000? we ran clean out of diesel and so did all the fuel stations, so, indesperation we ran our old LDV box van on PARAFFIN!
AFTER we had done this someone told us we should have mixed a little oil in with the paraffin to lubricate the works!
We did however get away with it (only used for a short period) and the van was in use for a long time after that.
Parrafin, IIRC, is what is known as Kerosene, which is jet fuel. Petrol based fuels tend to be 8 carbon atoms per molecule, keronsene IIRC in the 10-14 C atoms range, and diesel 18 or so. I would have thought off the top of my head that parrafin and petrol (assume octane) were more similar in viscosity than diesel vs. parrafin. In short I am surprised that it worked okay without a viscous addative.
The S60 sounded very rough (very truck like) on startup last week after sitting for 48 hours in -15 deg conditions. 20 seconds later it sounded fine.
Anyone who watches Ice road Truckers (new series starts soon) don't they have almost -50 and their trucks still start.
like military vehicles designed for cold weather I suspect they have heated fuel tanks and insulated fuel lines ready for it,
farmer next door to us is retired and he has 2 barns full of vintage tractors. his son visits every week and they get 3 or 4 out and run them round the yard. some of the older ones have to be started on paraffin and some started with an explosive charge. he's 83 years old and when I had a gardening firm round to cut some trees down and chip em up the tractor he was using to drive the chipper broke down [engine was running but power take-off and gears weren't]. the owner of the firm was scratching his head as we all looked at this knackered tractor. old man next door pops his head over fence, oh thats a common fault on them he says, and comes round with a crowbar,opens up an inspection hatch and levers some cog wheels and we hear a clunk and hey presto fixed
In Canada they have sockets near supermarkets you plug your truck into. Which will have a block heater and possibly fuel, sump heaters.
Someone I know also when it's really cold wont turn the engine off and leaves it idling all night, this is a Hilux.
The trucks will probably have diesel fueled heaters for the water and this will be passed through the oil and diesel tanks.
In Mongolia we had the diesel turn into a jelly type substance and cause problems, this was only with a few fuel deliveries so presume the additive mix was wrong on these.
if it's cold i'll normally run in a lower gear for a bit longer to get some heat into the engine. Luckily the Merc is showing at least 60°C water temp in less than a mile in all weathers.
My diesel Golf was awful in getting warm but didn't really sound any different in freezing or warm temps.
Dave!
