Comand carphone
philsy2k
newcastle
C36 AMG
I have a Mercedes comand carphone from an s-class new shape, i have just the phone itself and was wondering what else i needed to link it to my comand 2.0, i think SYM was going to do this or already has? is it going to be expensive as i only have the phone?? any part numbers etc would be appriciated
Cheers
Phil
Just done it today Phil ! But I'm using a Nokia 6310i which has a separate cradle, and interface module.
Unless that phone pictured has optical output (like the CD Changer) , and all the associated wiring / microphone, and aerial, I'm not sure what additional kit you will need to make it work, in terms of a controller, and wiring loom.
What else is with it ?
S.
carphone
Thanks for replying, what you see in the picture is all i have, im guessing it will cost a bit and be a bit of a struggle to locate parts to work it, unless it could work through a nokia kit??? but i think the plug is different on the phone
It might have to end up on EBAY
Phil
Yeah - I expect you would need some other kit to make it work - even if you were using it with an S Class COMAND.
Possibly worth seeing if somebody with an EPC can check it against associated part numbers for you, before you put it on eBay.
S.
