Comand DVD / TV function
Howman
I have Comand Sat Nav for my 55 plate CLK but I have no DVD or TV function.
Can you get this added at a later date or does it require a full upgrade?
You can get it added but it wont be cheap!
Howman said:
What does that mean?
Likely cost?
Thanks by the way, heh heh
It means that there are companies out there who can add a TV tuner to your comand for you and also enable DVD playback. The OEM tuners are not cheap, circa £700 from memory. The labour to install it and then program your comand to accept it will not be cheap either. I would estimate the whole lot is going to cost you circa £1500.
Try sending a PM to Miro and ask him what he will charge to do it for you when he comes over in july.
Good guess. I seem to recall Braybrooks quoted me about that sum to have the TV Tuner added - and it wasn't a digital one either.
I figured next time order it OEM !
Not knowing what a 55 plate is I can say that any 2005 specification model can have digital TV (and later models). Have done just that myself.
It's the 2006 specification model so should be ok I guess.
Sorry bit ignorant here but anyone know any decent suppliers / fitters? I presume MB will be the best option but not the most cost effective.
If you are up to it ....
1/ Order a kit from MBENZNL now ([email protected])
- tuner
- antenna system (oem)
- wiring as needed
- bracket
- screws / clips
2/ Have it installed in July by yours truly
Timing is the only thing .... July 5 - July 10
- tuner
- wiring as needed
- bracket
- screws / clips
How much mate and where? The timing is fine.
Alfie said:
Cant comment on costs but you can contact steve at [email protected]
As stated ..... order the kit ASAP (C55 shown)
Main Screen TV activation
Trunk setup
Additional items added to the car for entertainment (DVD + MP4)
Adding your location
http://www.frappr.com/modzworldtour
Sent the fella a note but he has not come back to me yet.
When he does, I'll assess the cost and let you know straight away.
Thanks again
